- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000P Wifi - 5Ghz not working and router says incorrect password on all clients after 5-10 minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model: R7000P
FW: V1.2.0.22_1.0.78
Tried Resetting: Yep, already factory reset and still see the same behavior.
Setup: New R7000P setup with 2.4 and 5 Ghz band of same name using WPA2-PSK. Currently it shows only a green check near the 2.4Ghz status under Advanced Home, but Advanced > Wireless Setup > 5Ghz > Enable SSID is checked.
What Happens:
1) Obviously no 5Ghz showing up on any clients that used to work with 5Ghz on old router.
2) After 5-6 min of heavy use, all of the clients lose connection but the router lights stay on. The windows clients just time out, iOS says incorrect password. This seems to correlate with using Netflix on our TV, but that might just be what is making us notice.
What I've Tried:
I reset the router since tihis didn't happen for the first couple hours after initial setup. But it immediately had troubles and took about 20 min before the 2.4 Ghz network showed up again. The 5Ghz radio still isn't working and it is still denying use after a couple minutes.
Any ideas? Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi James. I attempted that but it kept showing the 5Ghz as not active (red x on advanced home page). I ended up returning it and getting a new one which fixed the problem.
Thanks!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000P Wifi - 5Ghz not working and router says incorrect password on all clients after 5-10 m...
Hi yet112,
Try using a different names for both networks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
