Orbi WiFi 7 RBE973
Reply
R7000P bricked tftp not possible
markymark22
USB-TTL through puttyUSB-TTL through putty
After a firmware update went bad I am unable to reset or reflash my router. I has a USB-TTL cable connected to the internal header but what is coming back looks like complete jibberish, can anyone advise? tftp has not proved possible as the router seems to be cycling itself - 3 ping responses, 3 unreachables, a block more ping responses etc etc. Screenshot attached.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 5
Accepted Solutions
markymark22
Re: R7000P bricked tftp not possible
Worked it out. Pin connections from left to right with the router facing you (serial header on front right of board) should be Tx, Rx, Gnd. 4th pin (most right) not connected. Data comes through fine with 115200, 8-N-1 settings
Message 4 of 5
All Replies
antinode
Guru
> [...] I has a USB-TTL cable connected to the internal header but what
> is coming back looks like complete jibberish, [...]
   Bad serial-line characteristics (speed, bits, parity, ...)?
> [...] tftp has not proved possible as the router seems to be cycling
> itself [...]
   Forget "ping", and try to find a timing window?
   In-line images in these forums must wait for moderator approval, so I
can't see yours yet.  (An attached file incurs no such delay.)  Some
little description would be nice, even if the pictures were visible.
Copy+paste of plain text can be more useful than pictures of plain text.
Message 2 of 5
markymark22
Hopefully the screenshot is attached this time rather than embedded.
Message 3 of 5
markymark22
Message 4 of 5
markymark22
Just to add - if you are using the TTL cable to flash back to stock firmware then once the process has completed you will need to remove the static IP from the ethernet connected computer else you will only reach the first setup page (auto update and data gathering) before moving onto the routerlogin.net page which will not load. If you have the serial connection still up you will see "handle_genie: don't know how to process url". Make your static IP a dynamic one and reconnect and all will be good. That one had me spinning my wheels for a bit before locating this.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3124 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
