Orbi WiFi 7 RBE973
Reply
R7000P drops internet connections
ajs123
This is a brand new R7000P, set up yesterday. There are no other routers, repeaters, etc. in the house and the nearest neighbor is about 200 yards away.  Below is an image from WiFi Explorer on a Mac. Smart Connect is on, so both bands have the same name. I recall a reference while I was researching options to this being a problem with a small number of these units so I'm concerned.
Thanks for any help.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 2
Accepted Solutions
ajs123
Re: R7000P drops internet connections
It turns out that this was an issue with how the WiFi signal is detected by the tool I was using. The author provided this helpful tutorial: https://www.adriangranados.com/blog/understanding-scan-modes-wifiexplorerpro
Message 2 of 2
All Replies
ajs123
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2102 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
