Reply
R7000P iPhone on 5GHz cannot connect to Airplay device but can on 2.4GHz
dsberger
I have a R7000P router with SmartConnect enabled so both the 2.4 GHz and 5 GHz networks share the same SSID. I have a Yamaha HTR-4065 receiver with a hardwired connection to the R7000P router that I have been able to use Airplay to send audio to. However, I cannot see the Yamaha receiver from iOS devices or Macs connected on the 5GHz network, but I can if the iOS device or Mac is on the 2.4 GHz network. Any suggestions on how to fix this so I can continue to use SmartConnect?
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 2
dsberger
Re: R7000P iPhone on 5GHz cannot connect to Airplay device but can on 2.4GHz
Yes. I have the latest firmware installed.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 530 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
