Reply
HalJordan9
Tutor
R7000P losing 5GHz password, reboot fixes for a short time
Help! I see others have had this problem on different models. I’ve started a new string to be specific to my model.
We lose WiFi after a couple of hours of use. Fix requires turning Nighthawk off/on and hitting reset button on the Verizon box (holding it down for 20 seconds). I’m not even sure this is the best way to reboot but it works. After a couple of hours - we lose WiFi again and my phone tells me it’s the wrong password. I have not changed the password. I did do a firmware upgrade but that was after the problem started.
Thank you in advance for your help.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: R7000P losing 5GHz password, reboot fixes for a short time
 Does this ever happen on the 2.4 ghz? Have you tried to adjust the 5ghz channel?
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 210 views
  • 0 kudos
  • 2 in conversation
Announcements
