- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000P
- Mark as New
- Bookmark
- Subscribe
- Permalink
R7000P
In my genie it shows my wireless signal is off with a yellow triangle with an exclamation point in it. Does that mean my wireless is burned out or what?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000P
There a screen capture of this you can post for us to see?
Is the WiFi button on the router been pressed for 5 seconds then release?
Try a factory reset and setup from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000P
What about the wifi LEDs on the thing?
What about the wifi on/off button on the thing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000P
All lights are on and I even factory reset the router. I turned off and on the Wifi button and even logged into the router and turned off and on the radio signal and still nothing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000P
Did a factory rest and turned on and off the Wifi button and the radio signal twice and still nothing. It has the latest firmware and I have Comcast 1gig internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000P
Does the wifi radios show as enabled on the routers web page under Advanced tab/Advanced/WIreless settings? Should be check marks seen in the boxes that indicate the radios are enabled.
If not, possible the wifi radios are toast. You could just disable these check boxes and connect up a external ethernet connected wireless AP or router configured for AP mode and continue to use the R7000P for it's wired abilities.
