Reply
R7000p slow
Debz67
R7000p slow
Hi,
Can anyone solve this? I have a 350Mbps contract with Virgin & use their router in modem mode. I have a desktop wired connection to my nighthawk & easily get 350Mbps dowloads on it, but tests show my Router only receiving about 200Mbps apparently. Thus, my wifi is not performing as expected.
Message 1 of 7
Guru
Re: R7000p slow
Which tests are only showing 200mbps?
Are you testing over 2.4ghz or 5ghz?
Have you changed channel for the wireless?
What device are you testing on? This is key as a 1x1 antenna solution isn't going to have the same speed as a 2x2 device.
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 7
Debz67
Re: R7000p slow
I'm using the speedtest directly from the router! Sorry if that wasn't clear. It's part of the netgear service
Message 3 of 7
Guru
Re: R7000p slow
Try using a hardwired device and use the browser based sppedtest, and try different servers on there. The built in Netgear doesn't always give accurate results.
Message 4 of 7
Debz67
Re: R7000p slow
Hmm. I believe I already stated in my original post that I was getting 350 on a "hard-wired" connection. My question is why the router 'thinks' it's only receiving 200!
Message 5 of 7
Guru
Re: R7000p slow
Because the built in speedtest app doesn't always choose the fastest server. It usually chooses the closest and if the closest one is a slow server, then your speeds will show as slow.
Message 6 of 7
labatt
Mentor
Re: R7000p slow
Think of the Netgear speed test as a check to see if you have connection to the Internet and not a true speed test.
Modem CM2050V
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 370 views
  • 0 kudos
  • 3 in conversation
Announcements
