Reply
R7000p
spear625
R7000p
My printer will only find and connect to the guest network which is not secure. How can I connect to the secured network?
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 3
schumaku
Guru
Re: R7000p
If you know the normal network name and of course the configured network security key. Unless the broadcast is hidden, the network should become visible, so a click and entering the network key (passphrase, password) does allow to establish the connection.
Message 2 of 3
spear625
Re: R7000p
Thank you for your reply. I have tried this but it did't work! Any other suggestions? I do have an older printer (HP Envy 110 series) I don't think it's dual band, could that be the problem?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 310 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
