Reply
R7300 - Unable to set up QOS rule per device
joeldsouza
Follower
When I visit the page around QOS instructions for the NETGEAR Genie routers :- https://kb.netgear.com/24266/How-to-enable-Quality-of-Service-QoS-on-routers-with-NETGEAR-genie?cid=..., I see that there are options to "Setup QOS Rule" under the WMM options.
Where can I find that for the R7300 with Firmware Version V1.0.0.46_1.0.13?
Here's what I see :-
Missing QOS rule settings
Thanks,
Joel
Message 1 of 2
Guru
Re: R7300 - Unable to set up QOS rule per device
You can enable/disable dynamic QoS on the other page.  I think that's all the control you have with your particular router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1143 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
