- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7450 Firmware Version 1.2.0.76 Update causing Connectivity Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I am trying to troubleshoot my R7450 Router. I did not notice what version of the firmware I was running before I updated to the latest 1.2.0.76. Immediately after updating I noticed my Android phone kept disconnecting from the 5Ghz WiFi, on my computer I was only seeing the 2.4Ghz connection but not the 5Ghz. No issues connecting to the 2.4Ghz.
I have attempted to roll back from 1.2.0.76 -> 1.2.0.74 and even as far back as 1.20.0.42 and I am still getting experiencing these connectivity issues. It goes without saying I have alread tried unplugging and plugging back in the router and even my modem several times as well as restarted the devices I am trying to connect with.
Hope someone can help, thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7450 Firmware Version 1.2.0.76 Update causing Connectivity Issues
Instead of a restart, try a factory reset and do a clean install (not from backup)
simply push and hold reset for 7-15 seconds while its powered on. Then manually reinstall it. Again, don't use a backup.
That's usually what we recommend first if there's issues after changing firmwares.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Similiar problem with Firmware Version 1.2.0.76 released on 12/8/2020 has completely disabled remote access (web service mang) feature. Anyone tell me if there is a work around or tell me how to go back to an earlier version of firmware so I can get back my remote access?
