Reply
R7450 Ping Spiking and Assigning Multiple IP's to same MAC Address
Alexguy891
I currently have an R7450 plugged into my AT&T Gateway and I have 2 large issues.
The first issue is that on my PC, my ping seems to randomly spike from around 32ms to about 150ms, at random times.
The second issue I have is that in my Attached Devices list, if my computer is turned off, my parent's computer and my brother's Xbox One show up and have no issues. However, the second I turn on my computer, those devices lose connection, and my computer seems to take on multiple IP addresses, including the ones the Xbox and my parent's computer were using. The computer is listed multiple times, with different IP addresses, but the same MAC Address. I have no idea what to do to solve these issues.
I ran a ping test for around 15 min and here are the results:
Pinging 8.8.8.8 with 32 bytes of data
Reply from 8.8.8.8: bytes=32 time=32ms TTL=53
Reply from 8.8.8.8: bytes=32 time=33ms TTL=53
Reply from 8.8.8.8: bytes=32 time=34ms TTL=53
Reply from 8.8.8.8: bytes=32 time=35ms TTL=53
Reply from 8.8.8.8: bytes=32 time=31ms TTL=53
Reply from 8.8.8.8: bytes=32 time=48ms TTL=53
Reply from 8.8.8.8: bytes=32 time=85ms TTL=53
Reply from 8.8.8.8: bytes=32 time=121ms TTL=53
Reply from 8.8.8.8: bytes=32 time=42ms TTL=53
Reply from 8.8.8.8: bytes=32 time=125ms TTL=53
Reply from 8.8.8.8: bytes=32 time=36ms TTL=53
Request timed out.
Reply from 8.8.8.8: bytes=32 time=54ms TTL=53
Reply from 8.8.8.8: bytes=32 time=167ms TTL=53
Reply from 8.8.8.8: bytes=32 time=116ms TTL=53
Reply from 8.8.8.8: bytes=32 time=101ms TTL=53
Reply from 8.8.8.8: bytes=32 time=103ms TTL=53
Ping statistics for 8.8.8.8:
Packets: Sent = 341, Received = 340, Lost = 1 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 31ms, Maximum = 167ms, Average = 34ms
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 9
antinode
Guru
Re: R7450 Ping Spiking and Assigning Multiple IP's to same MAC Address
> I currently have an R7450 plugged into my AT&T Gateway [...]
   Does your (unspecified) "my AT&T Gateway" have a maker and model
number?  What, exactly, is "plugged into" what, exactly?  If a device
has different types of Ethernet ports, then "connected to device" is not
enough detail.
   What's the reason for connecting the R7450 to your (unspecified) "my
AT&T Gateway"?
> [...] my computer seems to take on multiple IP addresses, including
> listed multiple times, with different IP addresses, [...]
   Again, to what, exactly, are all these devices connected?  What are
all these IP addresses?
> [...] I have no idea what to do to solve these issues.
   Having no actual information with which to work, it's all a mystery
to me, too.  Copy+paste of those Attached Devices reports might be
interesting.
Message 2 of 9
Alexguy891
Here is the my ipconfig /all page on my desktop.
Message 3 of 9
Alexguy891
I keep trying to post a reply and I cannot tell if they are showing up.
Message 4 of 9
Alexguy891
The gateway is an ARRIS BGW210-700. It has an ethernet running from it to the R7450 in the internet ethernet port. I attached an image of my Attached Devices page, my computer is DESKTOP-T6615N8.
Message 5 of 9
antinode
Guru
> The gateway is an ARRIS BGW210-700. [...]
   That's a "gateway", (modem+router), which is why the R7450 is using
"10.0.0.*" as its LAN subnet.  Cascading multiple routers can cause
multiple problems.  But not all these.
> DESKTOP-T6615N8. [...]
   I see "10.0.0.15" on two different devices, which should not happen.
Did someone configure one of those devices with a static IP address?
   I also see multiple "DESKTOP-T6615N8" devices which have the same MAC
address, which also should not happen.  If you have multiple devices on
your LAN with the same MAC address, then you can expect serious network
problems.  Is that one system which appears multiple times, or multiple
systems?
   What's the firmware version on the R7450?
   If I did want to persue the current configuration (which I wouldn't
-- see below), then I'd try powering off the R7450 and all those client
devices, then powering on the R7450, and adding the clients, one at a
time, to see what goes wrong when.
> AT&T Gateway"?
   Still wondering.  If the goal for adding the R7450 was to (partially)
replace the BGW210-700, then you'd want to configure the BGW210-700 in
some kind of modem-only ("bridge") mode.  I don't know it that's
possible.
   If the goal for adding the R7450 was to extend the wireless-network
coverage of the BGW210-700, then you'd probably want to configure the
R7450 as a wireless access point.  In that case, visit
http://netgear.com/support , put in your model number, and look for
Documentation.  Get the User Manual.  Read.  Look for "Set Up the Router
as a WiFi Access Point".
Message 6 of 9
Alexguy891
The MAC address with multiple IP's is just the desktop. I've attached an image of the Attached Devices page with the Desktop powered off. I do not believe any devices are configured to have a static IP. The goal was to have the R7450 as an extender, I will switch it to AP mode.
Message 7 of 9
Alexguy891
Firmware is on V1.2.0.50_1.0.1A
I originally suspected it was an issue with the firmware which is why it is not on the current version, but it was happening on that version too.
Message 8 of 9
Alexguy891
For some reason switching the R7450 into AP mode this time worked and my Desktop is now showing as only one device with one IP. Now the only thing left is the ping spike issue.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 426 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
