Orbi WiFi 7 RBE973
Reply
R7450 losing its mind since update to V1.2.0.76_1.0.1
wb5rue
Follower
Since I upgraded the firmware on my R7450 last week I've had to reset it back to factory settings and restore from the most recent backup.  I learned the hard way to create the backup after I had to completely rebuild all of the settings when it crashed the first time.  The first simptom was loss of internet and WiFi and the orange internet connection light.  When I tried to connect to the router I got the warning screen that "this site has been blocked...."  I tried the IP address and the routerlogin.net address and got the same result.  It's happened three times and doesn't seem to have a time of day pattern or set number of days between crashes.  Is there a problem with this firmware upgrade?  After I did a hard reset it came back with a fixed internet IP address of 0.0.0.0 instead of using DHCP.  It also kept giving my machine real odd IP addresses such as 145.44.69.251.  Isn't the default either a 10.x.x.x or 192.168.x.x?
Kevin
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 454 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
