Reply
R7450 only shows red power light
Fulmerb
Follower
I’ve never had a problem with this or any router for more than an hour. After we had a storm, and the power went off, the modem restarted, but the router didn’t. Instead it shows the power light as a solid red light. I’ve tried resetting the router, and power cycling it, but nothing has worked. I also switched my Ethernet cable, and that also didn’t work.
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: R7450 only shows red power light
You may of had a power surge and the router got hit I suggest contacting support.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 122 views
  • 0 kudos
  • 2 in conversation
Announcements
