Orbi WiFi 7 RBE973
Reply
R7500 5 GHz woes
MarkkuR
R7500 5 GHz woes
No AC wireless on firmwares after 1.0.0.94 – always stuck at 54 Mbps speeds. I've tried at least 10.0.0.108 and 1.0.0.122, but no difference. This is not a client issue either, as it's the same with three different computers. Wireless router radio is enabled. Have tried many different channels and all the available modes.
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: R7500 5 GHz woes
Message 4 of 5
All Replies
avtella
Prodigy
Also make sure WMM is enabled in QoS page as without that enabled no WiFi card or router would go over “g” specs. Otherwise a tftp firmware install might be needed if a reset to default didn’t help.
Message 2 of 5
MarkkuR
Thanks for the suggestions! Unfortunately, they didn't really seem to help. I'll try a factory reset later on, even if that didn't really do anything with the previous firmware.
Message 3 of 5
JamesGL
Master
Message 4 of 5
JamesGL
Master
Hi MarkkuR,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1012 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
