Reply
R7500 not routing if Internet drops?
Unbwogable
Follower
I've got the r7500, latest firmware update, and if my Internet connection drops, nothing will work. My roku shows its connected to WiFi, but cannot see my plex server, which is on the same intranet. Is this normal?
Message 1 of 2
Retired_Member
Not applicable
Re: R7500 not routing if Internet drops?
Some of the PLEXING if you will is being done outside of your LAN would be my guess. Or the routing function is actually stopped when WAN is down. If you want to test routing, try pinging the devices on LAN  when Internet drops. Remove WAN cable and try pinging local devices.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1609 views
  • 0 kudos
  • 2 in conversation
Announcements
