- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7500 stuck at network mode b/g on 2.4Ghz band
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using Wifi Explorer on the Mac I can see that my Netgear R7500 is using network Mode b/g on the 2.4Ghz band and is thus limited to a Max rate of 54Mbps - even though the Mode setting in the router configs lists b/g/n - as a result I'm seeing poor wifi performance on that channel. Pretty sure it wasn't always like this. Amy ideas what might be forcing the lower speed ?
Ian
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7500 stuck at network mode b/g on 2.4Ghz band
I beleive anything other than WPA2 will limit the rate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should have said, it's using WPA2
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disabled on both bands
- Mark as New
- Bookmark
- Subscribe
- Permalink
And voila - after enabling WMM I now see Mode a/c available and speed back up to 289 Mbps max Rate. Thanks - would never have thought of looking there !
- Mark as New
- Bookmark
- Subscribe
- Permalink
you might enable them seeing how it's part of the WIFI 802.11n standard
Edit I see you did. glad it worked
