Reply
R7500 with X6S EX8000
marcjuang
Follower
I have a R7500 for a while! And I used a EX6100 with it now but performance is no so good. Can I change EX6100 to EX8000 for more stable wifi environment?
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: R7500 with X6S EX8000
Yes you could upgrade the Ex8000 it is also a mesh extender so you can have the same SSID across the house and your devices will switch to the better wifi signal.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 245 views
  • 0 kudos
  • 2 in conversation
Announcements
