Orbi WiFi 7 RBE973
Reply
R7800 Bridge mode don't work
Naks
Hello,
I bought a R7800 (firmware 1.0.2.20), i link my computer and the router with ethernet, and i try to use the bridge mode on the Wifirst's public router. But when i set the bridge mode the routerlogin.com/192.168.1.1 webpage is not accessible, and the bridge don't work. I try to connect the router on the wifi AP of my android phone but i have the same problem.
If someone can help me it could be cool ! 🙂
Thanks,
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 24
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Re : R7800 Bridge mode don't work
None of our home routers supports such feature.
I'm not sure if 3rd-party firmware will help.
Message 22 of 24
All Replies
ElaineM
Re: R7800 Bridge mode don't work
Welcome to the community, @Naks
Did you follow the steps from the article below?
How do I set up my Nighthawk X4 to Bridge mode?
Message 2 of 24
Naks
Yes but when my router switch to bridge mode i cant access to the routerlogin.com page and my PC dont detect the router on the ethernet port.
Message 3 of 24
ElaineM
When the router is set on bridge, it's normal that you will no longer be able to access it through routerlogin.net.
You will need assign a static IP address by selecting "Use Fixed IP Address". Make sure that the IP address that you will assign should be in the same range of the main router.
Message 4 of 24
Naks
Ok, because i had access to the page routerlogin.net a little time like 45s in bridge mode, it's why ithink it was possible to go on it.
i try what you propose, but it's don't work. Maybe because i'm not configuring the bridge mode correctly, i'm not a pro 😕
I tried with the ip adress shown on my phone when he is connected to the main router for static IP.
Message 5 of 24
ElaineM
Just follow the steps on how to set it as bridge and do not forget to select "Use Fixed IP Address".
Once done, you should be able to access it through that IP address that you have just assigned.
Let us know any update.
Message 6 of 24
Naks
Yes i did, but now windows say: "Unidentified Network" when i'm connected with ethernet on the router in bridge mode.
Maybe because i don't write the right SSID ?
Message 7 of 24
ElaineM
Or the wireless security password.
Double check your settings.
Message 8 of 24
Naks
I check it 3 times but nothing work. There is not password it's a public router and we connet via a webpage 😉
Message 9 of 24
ElaineM
So when you connect to the public WiFi, it brings up a webpage?
What do you need to do on the webpage? Do you need to do anything to get Internet access or it just brings up the webpage and you can just simply close it and be able to browse?
Message 10 of 24
Naks
We need to connect with a login and password, but i have it i use them on my phone. With the router i don't have access to the webpage.
I can write any static ip, or i need a specific one ?
Message 11 of 24
ElaineM
Then I don't think it would be possible to use it.
There's no way on the router that lets you see that webpage and enter the login information.
Message 12 of 24
Naks
I can't just be connected to the main router and go on the webpage via my computer ?
My phone can do it then it's not impossible 😮
Message 13 of 24
ElaineM
Think of the router as your phone.
When you connect your phone to the SSID that it broadcast, as you said you need to connect with a login.
So, when you connect the router to the SSID that it broadcast, where do you input the login on the NETGEAR?
Message 14 of 24
Naks
I'm connecting my phone to the main router's wifi and after i go on internet for the connection one a webpage. Like a lot of public wifi 😉
Then i think i just need to connect the router on the on the main router's wifi network and link my pc on my router with ethernet. After that i should just access to the webpage. But no i can't it's the problem 😕
PS: the SSID is just the wifi name, i'm right ?
Message 15 of 24
ElaineM
Is the webpage a captive portal?
Like when you connect your phone, will the browser opens up automatically and you need to input the login?
Did you type the SSID just like how it was broadcasted (considering if there's capitalization)?
Message 16 of 24
Naks
Yes it's a captive portal. With my phone as bridge yes it opens up automatically.
yes i write the SSID like he is write on my phone wifi list with capitals.
The SSID is "SmartCampus" 😉
Message 17 of 24
ElaineM
The router wouldn't work to be in bridge mode if it's a captive portal.
The only way you can use it is to physically connect the NETGEAR to the main router.
Message 18 of 24
Naks
Oh, ok ! It's very problematic, i don't have access to the main router  😕
There is really no way to do this ?
Message 19 of 24
ElaineM
Sorry, there's no other way since there's a captive portal involve in connecting. 😕
Message 20 of 24
Naks
Ok then if this router can't do this, my phone can, then what type of device can ?
Message 21 of 24
ElaineM
Message 22 of 24
Naks
Ok, thank you very much for your time 🙂
i'll search on my own now 🙂
Message 23 of 24
ElaineM
You're welcome.
Have a great day!
Message 24 of 24
Top Contributors
Discussion stats
  • 23 replies
  • 12833 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
