Discussion stats
  • 1 reply
  • 1848 views
  • 1 kudo
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
R7800 - Change Device Name in AP Mode
I've already contacted support about this issue, but they were not helpfull at all.
I have put my R7800 in AP mode, but now the 'Device Name' menu under Advanced->Setup is grayed out. Support told me to change it back to router mode, change name, and then back to AP mode. Which I think is a bug in the firmware. Support didn't agree Smiley Happy
What do you guys think?
Using firmware version V1.0.2.12
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
Highlighted
Guru
Re: R7800 - Change Device Name in AP Mode
From my perspective it's a bug, and support gave you a workaround.
Support likely has been told that the behavior is "as designed" - at least that explains their response.  If so I think it's a silly restriction.
Message 2 of 2
