- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7800 Console access denied
- Mark as New
- Bookmark
- Subscribe
- Permalink
All of a sudden, when trying to login to my R7800 console (http://192.168.1.1) I am getting an access denied (see attached).
Thinking it was the result of some firmware update I entered serial # as prompted, re-entered questions and then clicked Login to login. No luck. It repeated the same problem. I then reset the router and, again, no luck same problem.
How do I overcome this nuisance? I did nothing to cause the problem and continue to suspect whatever latest firmware was updated as the culprit.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7800 Console access denied
I also notice that when I click Cancel in the attached screenshot, it refreshes the screen as if I was trying to access again. Isn't the point of cancel to go somewhere else? I am now more suspicious than before that some firmware update has mucked my ability to login in to console.
I am hopeful that someone in Netgear or an advanced Netgear user can help me through what is now becoming a terrible problem!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using Chrome 77? Try another web browser or try Chrome Canary.
Not sure if the bug is Netgear or Chrome -- but something is preventing username/password popup from being displayed properly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
