Orbi WiFi 7 RBE973
Reply
R7800 NighHawk X4S - 5Ghz Drama
omoeller
Guide
Looks like my 5 Ghz band got screwed after of hassle free weeks. I tried to reset, tried different FW versions and was not successful getting 5Ghz back to work. I finally ended up going down to FW .52 whcih now seems to work. I there any major risk staying on this version before Netgear gets next FW fixed or should I send back and replace this router. I never had such touble with my good old R7000 which I unfortunately sold ...
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 6
Accepted Solutions
microchip8
Master
Re: R7800 NighHawk X4S - 5Ghz Drama
I use .62 firmware but don't use the 5 GHz band much so no problems here. But there are users reporting it still has issues on .62. These issues are also present on .58 and .60 firmware. Your best bet is to stay on .52 and wait for a future update that hopfeully fixes it once and for all
Message 4 of 6
All Replies
Guru
Several people have been reporting problems with 5ghz on the newest firmware. If you don't have any other issues with the downgraded firmware, I'd wait for a newer version to come out. You could put in a ticket to netgear support to see if there is any beta firmware available to try.
Message 2 of 6
@omoeller
Search for user microchip8  (check his sig).  Whatever FW he is running on his R7800 is likely a safe bet.
Message 3 of 6
microchip8
Master
Message 4 of 6
omoeller
Guide
Thanks folks - will stick on .52 for now, BTW faced the same issues with Voxels versions as well - just as FYI
Message 5 of 6
microchip8
Master
might be hardware related. i don't know. But since it works on .52, there's something going on but I can't say what exactly
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1998 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
