Reply
R7800 OPENVPN SERVER won't connect when using port 443
TH35W4G5T3R
I have checked with the online port check tool. the port itself is open however when i try to connect to the server i get a soft connection reset and constant retries after to no avail. this is when i use the vpn service under advanced settings
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 3
JamesGL
Master
Re: R7800 OPENVPN SERVER won't connect when using port 443
Hi TH35W4G5T3R,
OpenVPN uses the following ports.
TUN mode - 12973 (for smartphone)
TAP mode – 12974 (for PC)
http://kb.netgear.com/app/answers/detail/a_id/23854/~/how-do-i-use-the-vpn-service-on-my-nighthawk-r...
JamesGL
Community Team
Message 2 of 3
JamesGL
Master
Hi TH35W4G5T3R,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2750 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
