Reply
R7800 Versions?
Beamster
R7800 Versions?
Are there subsequent versions of the R7800 Nighthawk x4x router?
Looking to upgrade from our WNDR 3700 which had several versions, so I wanted to check what to look for before buying.
Message 1 of 6
microchip8
Master
Re: R7800 Versions?
Nope, there's only one
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.91.1SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 6
Beamster
Re: R7800 Versions?
Thanks
Message 3 of 6
Re: R7800 Versions?
Unless you want to go mad and buy an XR500, which is a fancy gaming router based on essentially the same hardware as the R7800 and that has DumaOS firmware that comes in with a massive cost premium.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 6
microchip8
Master
Re: R7800 Versions?
He asked specifically about the R7800. The XR500, while it has the same HW, is advertised as a different product by NG. If you only look at the R7800 and nothing else, there's only one version
Message 5 of 6
Beamster
Re: R7800 Versions?
That's right, just the R7800 (price range).
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 514 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
