Orbi WiFi 7 RBE973
Reply
R7800 doesn't send WIFI Signal
simon1893
Follower
Hi guys, as you can see my router doesnt send the WIFI Signal although it is activated in the settings. It worked fine until now, as the 2.4 Ghz and 5 Ghz lights didnt start blinking anymore when the router started... what can I do?
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
Kitsap
Master
Re: R7800 doesn't send WIFI Signal
On the front of the router, the last two LED's on the right side are a combination indicator/switch.  You have most likely managed to manually turn off the Wi-Fi.  With the router powered on, press and release the LED second from the right.  Give it a few seconds to power up after you have released the switch.
Message 2 of 4
labatt
Mentor
Cats love to lay on routers as they are warm. Down side is they may turnoff the wifi.
Message 3 of 4
Toddlers are also good at pressing shiny buttons.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 619 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
