Reply
R7800 problem checking internet connection
RedOneUp64
Follower
So I recently got the Nighthawk X4S AC2600. I am using AT&T Fiber 1000 mbps internet. When I connect the ethernet from the modem to the router, the LED on the ethernet one port glows amber with it blinking. And on the internet LED, it is a solid amber. Also when I do start the genie, it gets to the part where it checks the internet connection and says there is a problem. I have unplugged and replugged the modem after two minutes and double checked to see if the ethernet is in the right place. When I go to the page and it asks me to enter in my MAC address, I click the next button and it does nothing for a minute before the page turns white. I am not sure what the exact problem is, and so far not much has worked. If anyone has any solutions, I would be glad to hear them.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
Re: R7800 problem checking internet connection
There is a manual for the R7800 somewhere at the end of this link:
>>> R7800 | Product | Support | NETGEAR <<<
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Discussion stats
  • 1 reply
  • 697 views
  • 0 kudos
  • 2 in conversation
Announcements
