Orbi WiFi 7 RBE973
Reply
R7800 sudden drop off in 5Ghz range
munaknif
Follower
Up until today, the router worked great, have had it for about 8 months. The firmware nor settings had been touched for months, but suddenly my 5Ghz band started acting weak. I can get my full 380Mbps near the router but just 10ft and 1 floor away, and the speeds now range between 20Mbps and 150Mbps where they'd previously been at around 330-360Mbps. Tested it on multiple devices and performed a factory reset, didn't help. Any idea why this has suddenly happened? Thanks.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
Guru
Re: R7800 sudden drop off in 5Ghz range
What actual firmware version are you on?
Have you tried reinstalling the firmware (in case it was corrupt) or downgrading a version?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 322 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
