Reply
R7800 to firmware 1.0.2.36
01R
Luminary
Luminary
if you installed this firmware have you noticed the internet goes out every few minutes seconds ???????
im still investigatin it may not be the firmware just askin here cuz i dont know whats causing it Smiley Sad
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 10
01R
Luminary
Luminary
Re: R7800 to firmware 1.0.2.36
ok im done with this firmware it  just keeps disconnectin the internet every few seconds im put on a difrent firmware il report back if the problem goes away
Message 2 of 10
01R
Luminary
Luminary
ok its only been a few minutes but i did full reset  put in another firmware and the weird disconnects stopped  for now il update more tomorrow
Message 3 of 10
Another firmware? Old one or the same one again?
Did you reset the router to factory settings after the first firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware.
First note down the settings – screen grabs can help here.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 10
01R
Luminary
Luminary
firmware 1.0.2.36 was the cause of the disconnects   i hope its fixed soon
Message 5 of 10
Does that mean that you did a factory reset after you flashed the firmware?
It isn't clear from your answer.
Just another user.
Message 6 of 10
01R
Luminary
Luminary
yes factory reset be4 and after with all firmware changes   it was a problem witht he .36 firmware  any news on netgear fixing it ?
Message 7 of 10
Who knows? With luck they will read this forum and spot the flurry of reports of dodgy firmware and "bricked" hardware.
Just another user.
Message 8 of 10
EddieChu
Tutor
I am face the same problem, any solution?
Message 9 of 10
Which problem in particular?
@EddieChu wrote:
...any solution?
See above.
Just another user.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 834 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
