Orbi WiFi 7 RBE973
Reply
R7800 will not hook up to a laptop running windows 10
ToddPals
I am so frustrated.  I have a laptop running windows 10 and I can see the netgear router and I am putting in the correct password but my laptop continues to say it cannot connect to the network.  Can anyone tell me what to do to fix this problem and explain it in simple step by step processes?  I am a novice.
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: R7800 will not hook up to a laptop running windows 10
Navigate to your routers web page.
Under the Advanced tab, navigate to Setup, then Wireless setup. You'll find these settings here...
I use UpTo300Mb on 2.4Ghz, manual channels 1, 6 or 11 and WPA2 and AES only.
Does your Laptop connect to the router with a LAN wired cable?
Message 2 of 5
All Replies
Guru
Message 2 of 5
Is this a wifi connection?
Message 3 of 5
ToddPals
Yes, it is a wifi connection.  I have it working now....thanks
Message 4 of 5
Guru
Glad you got it working. Enjoy.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2829 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
