Reply
R7800
Dljj
Follower
R7800
What wireless access points would be best for my WiFi router
X4s AC2600
Message 1 of 2
Accepted Solutions
Guru
Re: R7800
Are you looking for access points or extenders?
I know they're different but just seeking a little clarity.
Reason why is an access point hardwires into your router. You'd just choose an access point that had the specs you wanted and hardwire it in.
If you're looking for a wireless extender, then I'd recommend one of the line of triband extenders.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
All Replies
Guru
Re: R7800
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 312 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
