- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7850 - Power adapter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could I get some help in finding the right power adapter for my nighthawk AC3000 -R7850. Tried searching on few sites but I am not able to find the netgear original charger.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7850 - Power adapter
netgear doesn't sell replacment power supplies.
But luckily you can buy third party power supplies. Just make sure it has the exact same output voltage and polarity. It can have a higher amperage but not lower or you'll have stability issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
... and if you are lucky you will find a replacement that lists itself as being compatible with your Netgear router.
They are pretty standard. Something that works with one router should work with others. But check the specs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your response. I was looking for third party adapters but unfortunately I am not able to find the right specs for the charger.
I reviewed the entire manual / product data sheet for this router but it does not mention the specs for the adapter.
https://www.netgear.com/media/R7850_tcm148-80578.pdf.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Per the user manual:
• North America: 120V, 60 Hz, input
• UK, Australia: 240V, 50 Hz, input
• Europe: 230V, 50 Hz, input
• All regions (output): 19V/3.16A DC output
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Look at the label on the router. Top right-hand corner.
Different router, same layout.
Or check the broken charger.
