Reply
R7900 DNS Problems
DavidG1701
Initiate
R7900 DNS Problems
Hi all,
I've had my Nighthawk X6 R7900 for less than 2 months now without any problems until about a week ago.  My devices started having problems using the router's built in DNS feature. Names would not resolve and I'd get connection time outs.  I thought this might've been an issue with Comcast's DNS services so I changed the router to use Google's 8.8.8.8 and 8.8.4.4 addresses for resolution.  That didn't help.  Eventually I've started to manually configure each device (computer, phone, tablet, etc.) to override the DHCP provided DNS server (e.g. the router) with the Google DNS settings. That worked and they're behaving ok once again. Some devices, like a Chromebook we have, seem to be working ok still using the router as the DNS server.
I'm running firmware version: V1.0.1.26_10.0.23
Any ideas what could be going on?
Thanks for any help you can offer,
--David
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 4
DavidG1701
Initiate
Re: R7900 DNS Problems
As a follow up, I did a bit of testing and it seems like the DNS service on the router is dying / becoming unresponsive.
Here's a test I did while not able to resolve names from any device using the R7900 as my DNS server:
mycomputer$ dig @192.168.1.1 www.yahoo.com
; <<>> DiG 9.9.7-P3 <<>> @192.168.1.1 www.yahoo.com
; (1 server found)
;; global options: +cmd
;; connection timed out; no servers could be reached
I then rebooted the R7900 using the web GUI and after coming back up, the DNS service is working again:
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 63268
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;www.yahoo.com. IN A
;; ANSWER SECTION:
www.yahoo.com. 1750 IN CNAME atsv2-fp.wg1.b.yahoo.com.
atsv2-fp.wg1.b.yahoo.com. 54 IN A 98.138.252.38
atsv2-fp.wg1.b.yahoo.com. 54 IN A 98.138.252.39
;; Query time: 26 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Mon Jan 29 02:28:43 PST 2018
;; MSG SIZE  rcvd: 103
Has anyone seen a R7900's DNS become unresponsive after some time?  I've seen various DNS issues, including somewhat similar problems with other models.
--David
Message 2 of 4
jsirgey
I'm having this same issue as well, it's very strange as I can RDP into machines that are on the wired LAN but cannot access any external websites unless I change my DNS server to google.  Happens almost exactly 48 hours from when I initally plugged the router in for the first time.  I was running the latest firmware V1.0.2.10_10.0.29 when it happened.
Message 3 of 4
Guru
What is the Mfr and model# of the ISP modem? Built in router by chance?
Possible that the detected DNS services from your ISP could have been down or not working. If you changed to Google DNS and it now works, maybe an ISP DNS issue.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1304 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
