- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I tried to upload this firmware release as suggested.
Downloaded the link for the zip file.
I logged in. I went to Admin Tab, then Router Update (there was no "firmware Upgrade"), then I browsed for the zip file. I then clicked on "upload" and I get this window statement:
This site says: Please assign the correct file. The file format is #.chk.
So what gives with that?
I am not tech savy, and so you need to be clear about these downloads.
I read the other instructions about Manual Download and I think my computer person setup my router w/an ethernet cord, but the instructions for manual download does mention the *.chk file, but I didn't unzip the file.
Please help!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You just need to unzip the file you downloaded. The .chk file is in there and will be placed on your computer when the original file is unzipped. If you are on a windows computer you can probably right click on the zip file ansd select unzip.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R7900 Firmware Version 1.0.1.8
Oh yeah by the way. Make sure you connect your computer up to the router using a ethernet cable and not using wireless when doing the upgrade. Also make sure you reset the router by pressing the recessed reset button on the back of the router until the power light turns orange and starts flashing, after you install the new firmware and let the router boot up to all white lights before doing a reset. People have problems after a firmware upgrade if they do not do a reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks, that worked. Extracting the .chk file was the trick. Firmware updated successfully.
