Reply
R7900. How to change from AP Mode to Router mode
Babaagba
Router currently configured in AP mode, but will like to change to Router Mode to use Circle Home for Monitoring.
Cannot do this in current Mode as copied below, hence trying to change to router mode to no success as there seems to be no option offered to change/toggle Mode with everything Grayed out except these 4:
Wireless SettingsWireless AP / USB Setting and LED Control Settings
Nighthawk X6 R7900      Operation Mode:Access Point
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 3
schumaku
Guru
Re: R7900. How to change from AP Mode to Router mode
How to set your Nighthawk router to Router mode
Alternate appraoch: Unplug from the network an do a factory reset, and reconfigure from scratch -> https://www.netgear.com/support/product/R7900#docs
Message 2 of 3
Babaagba
Yeah I tried using the original article you cited for hours to no avail, hence why I started this post..... Guess I have to start from Scratch as you suggested which is a bummer as I have this setup for years with a lot of devices connecetd to it.... Anyway thanks for your help....
Message 3 of 3
Discussion stats
  • 2 replies
  • 500 views
  • 0 kudos
  • 2 in conversation
Announcements
