Reply
R7900 Nighthawk AC3000 No Internet Connection
Alemer3
Follower
Device:
Nighthawk X6S AC3000 Tri Band WiFi Router /R7900P
Issue:
-No wifi/wire connection available
-Amber LEDs /Power LED
Troubleshooting steps[summary]
-plugged labtop via wire cable port 3.
-(made sure external wifi connections were NOT present/turned off wifi)
-IPconfig shows no gateway
-unable to connect via browser to
192.168.1.1
192.168.0.1
Turned off/on Router - same result
tried factory reset - same result
downloaded netgear genie for windows
(again made sure isp cable and cable to laptop are plugged
netgear shows no connection from
device to laptop
isp to device
note device power still amber.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
Re: R7900 Nighthawk AC3000 No Internet Connection
There is something wrong with your firmware.
There is a manual for the R7900 somewhere at the end of this link:
>>>> R7900 | Product | Support | NETGEAR <<<<
See page 173.
You may have to resort to TFTP.
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
That is a bit out of date in that it does not tell you that Windows has a TFTP function built in, you just have to enable it.
  • Control Panel
  • Programs and Features
  • Turn Windows features on or off
  • TFTP client - enable
That's probably easier than retrieving TFTP software from a website.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1661 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
