Orbi WiFi 7 RBE973
Reply
R7900P - Does not retain configuration
bgnewb
Follower
Since last couple of power outages I noticed that my netgear route is not retaining the configuration chagnes (like wifi name, password, etc) and going back to factory default. I tried resetting the route manually also and it does not retain the setting.
Also having some other power related issues and thus it is painful to do the setting again and again. There is no option to export the configuration as weel that would have saved some time.
Any suggestions other then buying the new router 🙂
Thanks for your help
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 2
antinode
Guru
Re: R7900P - Does not retain configuration
   Firmware version?
> [...] I tried resetting the route manually also and it does not retain
> the setting. [...]
   Sounds to me like bad hardware.  Have you tried a settings reset
before reconfiguring it?
> [...] There is no option to export the configuration as weel that
   Your unbounded confidence is impressive.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for
"Manage the Configuration File of the Router".  But, if the settings are
lost spontaneously, that that's only a work-around.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 288 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
