Orbi WiFi 7 RBE973
Reply
R7900P Firmware Issue Version 1.4.2.84 / Browser Issues
BillS22
Star
After upgrading my R7900P to Firmware Version 1.4.2.84 I started getting Browser Issues.
Both Chrome and Edge would fail loading web pages.
I down graded the firmware to the last previous version, 1.4.1.68, and the Browser Issues went away.
Just an FYI in case you are having problems.
Bill
Message 1 of 10
Accepted Solutions
BillS22
Star
Re: R7900P Firmware Issue Version 1.4.2.84 / Browser Issues
Thanks for the reply.
I didn't reset because I have been using this router for a long time with no firmware issues until now.
Also, I have been using the Armor / Bitware Protection for nearly to years, and again have not had an issue until now.
So, I am convenence it's the Firmware: 1.4.2.84. Perhaps it's a get-ready-for-Windows 11 issue.
Many software suppliers are re-writing their apps in preporation for Win 11.
I don't know, and I am running Win 10, not 11. But I've never had a Firmware issue until this version.
I'm happy sticking with 1.4.1.68 until ver 84 is fixed.
Thanks again for the response,
Bill
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 5 of 10
All Replies
Guru
Di you factory reset and set up from scratch the router after applying the .84 FW version?
Message 2 of 10
ilteq
I upgraded my R8000P to version 1.4.2.84 today and have been having the same problems. Web pages randomly fail to load on both wired and wireless devices. I factory reset the router and the problem was still there.
I then downgraded to 1.4.1.68 and the problems are gone.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 3 of 10
Guru
Thannks for confirming.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy.
Message 4 of 10
BillS22
Star
Bill
Message 5 of 10
Guru
Message 6 of 10
1jm2
I am having the same browser issues with Version 1.4.2.84. How do I downgrade to the previous firmware version?
Message 7 of 10
1jm2
I figured it out. I reinstalled Firmware Version 1.4.1.68 and problem solved!
Message 8 of 10
BillS22
Star
Yup. Just install the older version on top of the new.
Message 9 of 10
BillS22
Star
I tried the new firmware again, ver 1.4.2.84.
However, it still causes problems with both Microsoft Edge and Chrome.
Both browsers report URL problems and lists the URL's as invalid.
I down graded to ver 1.4.1.68 and the internet problems went away.
I have recently upgraded to Win 11 and I experienced this problem with both Win 10 and 11.
Bill
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2897 views
  • 7 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
