Reply
Highlighted
R7900P diagram of lights
Because of the way I have my router placed, I can see the LEDs, but cannot see the labels for what they mean. However, I can count from top or bottom to see which LED is blinking, colored amber, etc.
What I need is a photo or diagram of what the LEDs are, that is, how they are labeled. The manual only tells you what each LED means. What I need to know is which LED is which.
Any help?
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 4
Highlighted
Guru
Re: R7900P diagram of lights
Message 2 of 4
Highlighted
Thanks. Of course, I had see that. But there needs to be a clear photo/diagram of all the lights with their labels. In my situation, I can see the lights clearly, but not what each one indicates. If I had a diagram, I could then understand them.
Message 3 of 4
Highlighted
Guru
It literally marches down from the top. top=power 2nd=internet etc.
or go up from the bottom. bottom=wps 2nd from bottom=wifi on/off
and so forth.
I dont' have one so I can't take a picture of mine. But I did find one on myopenrouter.com
CAX80-> RBK53-> GS716v2-> TP-Link M9Plus
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 339 views
  • 0 kudos
  • 2 in conversation
Announcements
