- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R7960P firmware not upgrading
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
you don' t need the reciept if you bought it from Costco. Let me know if you return it and what you get instead?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello DarrenM (NETGEAR Moderator),
Based on your response I see that "you have escalated this issue to engineering to investigate."
Do you have update form your engineering, please let us know as soon as you can.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I’ve since moved on to TP-Link. It’s been solid. Unfortunately I can no longer recommend to anyone to use any Netgear product. The TP-Link comes with a 2 year warranty and lifetime built in Network level Anti-Virus and Anti-malware protection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks, I returned it this morning. Costco took it back and didn't even question it. I told them the problem and I was recommended to next time return it to Costco instead of trying to get Netgear to fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes that where I am heading, looks like that where Netgear wants all there customer to go.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
We are working on a fix for this issue but a workaround is trying to load the new firmware via TFTP I linked how to do this below.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@DarrenM wrote:
We are working on a fix for this issue but a workaround is trying to load the new fir...
DarrenM
Darren,
I see the hot fix available on your support web site:
"https://www.netgear.com/support/download/"
Firmware Version 1.4.1.56 - Hot Fix
Is there a reason that this won't upload using the Netgear Admin "Router Update - Browse" function (using a wired connection, of course)?
Does this hot fix need to be applied ONLY via your Tftpd64 software? The release notes don't indicate that Tftpd64 is required, and Tftpd64 is a whole lot more complicated, with many steps for regular users to navigate. Tftpd64 seems like an unnecessary stumblinig block.
@DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Best way to update is manual. PC/MAC Ethernet connected to the router. Download the firmware. You can get the firmware and user manual from this site.
Normally there is a howto included in the downloaded firmware zip file. The zip file needs to be expanded to use.
Hot fixes are not normally available from the router update process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The router never initiates the upgrade. It's almost like the user does not have access to write in that partition. Hard denial and reboot so you cant access the logs or any elevated privilege.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I attempted to manually instal the beta version. IT FAILED! NO SURPRISE.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ultimately I had to give up. The router was constantly dropping connections on the 5GHz bands. So I went with another brand. This was the second router that Netgear ruined because of firmware updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@DarrenM
Have YOU actually tested this firmware hot patch on an R7960P router? Has anyone at Netgear ACTUALLY tested this firmware patch on a R7900 or R7960P router?
If your techs are experiencing inconsistent test results, i.e. it works for some R7960P routers, but not others, or not every time, I'd like to offer my router as a sample of one that DOES NOT accept Netgear's firmware patches. I am a technical professional, and can work with your tech's to execute tests. We can either set up a second, parrellel router and configure my problem R7960P in a separate subnet, to conduct repetitive tests. Once we have a solution, I'll even write the tech note to document the solution for users.
This has gone on for over four months, and it's well past time for Netgear to solve this problem.
My contact information is available in my profile.
@DarrenM wrote:We are working on a fix for this issue but a workaround is trying to load the new firmware via TFTP I linked how to do this below.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yeeeaaahhh.... I'm a network engineer with 15 years of experience and spent two hours messing with this which is too much. This is a case of very poor quality testing on rolling out firmware to EVERY model.
I will take it back to Costco this weekend to get full refund and look in another direction. Which is sad for Netgear too, they are losing out on three new additional customers as I was due to hook up some friends and family home networks that are working remotely and want better wifi coverage and also parental controls. I was about to recommend multiple Netgear products to them, but not now after this poor personal experience. I will use different products for myself and all friends and family in the future.
I watched this exact thread for months waiting, they did not respond in a resonable amount of time with an actual fix. The whole you can "try" doing the TFTP upload as a workaround was a joke. @DarrenM
I'm most dissapointed that this firmware is for security fixes and we can't get the patches! Grrrr...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Sure would have been nice if this had been thoroughly tested before putting a bunch of people through the pain of taking everything off the network and going through the motions because everything STOPPED working at the point where you said Un-Plug the router. When I unplugged the router my tftp Server Interface immediately changed to Loopback Local host so when I clicked on PUT, it was PUTTING to the Local Host address. Then the Orange light that supposed to come on solid then start flashing, NEVER started flashing, it went straight to bringing the whole router up. So there was never a time when I could get the TFTP even act like it was working. How can Netgear have a problem firmware for several months and NEVER even ackowledge that it has a problem, and NEVER takes the time to inform their customer's of ANYTHING. I believe that DarrenM was suckered into posting this crap online just to stop the complaints. The last Netgear Router I will ever purchase. The range on this router was only slightly better than a 7 year old router I was using before this one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yeah, it toggles to the loopback and you have to force it back quickly.
All efforts are worthless though... I tried it like a dozen times at various times with a continous ping going and know connection between tftp and router were fine. I had the same issue with the power light. Super annoying we are following a doc that isn't accurate for our model.
Did you buy from Costco? Just take it back.. which is super annoying, having the whole household down while you have to deal with it at the store.
For how much time we are spending on this, I think Netgear should be giving us a $50 or $100 credit or something.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Well, we may all be talking about different routers with similar problems (i.e. not upgrading to the "latest" March 2020 firmware version). I've seen references to the R8000, and others.
Taking this back to Costco is not that simple. I purchased this unit on sale (R7960R/Nighthawk® X6S AC3600 Tri-Band WiFi Router) last January for about $150.00. I can't replace it with anything nearly as fast, or with the same range, unless I go to a $250 to $400 unit. Costco is out of anything comparable, but is currently selling Netgear's their DUAL band AC1900 router for $179, and most other units are out of stock (e.g. TP-Link). Amazon's prices aren't much different ($230.00 for this unit).
Bottom line, my unit works fine, as long as no one hacks it because it lacks security patches, and I'm not willing to ante up $100-$150 more to get the same performance. I too, am probably using my last Netgear product of any kind, but for now, returning it is out of the question.
(My guess is that supply chain disruptions between China and the USA are causing router shortages, and scarcity is raising prices. This may also be why we're receiving no support for Netgear's products, if most of their higher level of technical support is China based, or if the China-US corporate support links are "damaged".)
For now, I'm holding pat, and keeping the firewalls on my individual network devices tight. (If all else fails, I could hook up an old server configured as a primary firewall, but I don't really want to go through the setup and maintenance hassle. That's why I buy a router like the R7960p.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Same problem no firmware updates have worked for the past 3-4 versions...called the support line and the only option given was: pay for extended support and they will fix the firmware. I have no confidence this would fix the issue. Save your time and avoid the headache by returning Netgear products (if possible) and purchase from another company that will stand behind their product. Netgear has failed miserably!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
They are loosing many previously loyal and happy customers because of this! Please fix!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
i finally took mine back to Costco for a refund. Don't worry about purchase date. Costco does the right thing unlike some companies we might know.
User | Count |
41 | |
22 | |
10 | |
7 | |
7 |
