Reply
R8000 2.4 band drops devices and locks me out
Stimey58
2.4 band seems to choke when adding my tplink smart plugs and switches. Came from r7000 with no issues same devices. Have reset, rebooted, changed channels and no difference. When I try to use the 2.4 band from my phone it gives the invalid pw response. I’ve had it.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Stimey58
Re: R8000 2.4 band drops devices and locks me out
I’ve used nighthawk app and genie to no avail. Connected locally and remotely. Seems to only affect the 2.4 band the 5.0 bands work fine. Unfortunately most of my devices only see 2.4
Message 2 of 3
DarrenM
NETGEAR Moderator
Have you tried to rename the 2.4ghz or change the password? or even just to test make it so its not password and see if the phone will connect.
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 253 views
  • 0 kudos
  • 2 in conversation
Announcements
