Reply
R8000 2.4Ghz stops working, 5Ghz fine
zimson
Follower
fw: 1.0.4.18
2.4ghz keeps turning of after some hours. even the led for it turns of.
any ideas about this?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: R8000 2.4Ghz stops working, 5Ghz fine
Have you checked to make sure the schedule settings are disabled? also you may want to factory reset the device by holding the reset button for 10+ seconds then try to set the router up again.
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 362 views
  • 0 kudos
  • 2 in conversation
Announcements
