Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 Firmware Update R8000-V1.0.3.36_1.1.25 breaks genie app, local and remote management
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-27
04:43 PM
2017-03-27
04:43 PM
Upgrade to V1.0.3.36_1.1.25 has left me not being able to remotely or locally manage router using the genie app. I have also noticed the router being very sluggish with connectivity since the upgrade last night. Resetting does not resolve the issues.
Solved! Go to Solution.
Message 1 of 10
Labels:
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-28
05:59 AM
2017-03-28
05:59 AM
Do I need the previous fw to roll that back? If so where can I get it? Thanks!
Message 3 of 10
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-28
03:57 AM
2017-03-28
03:57 AM
Re: R8000 Firmware Update R8000-V1.0.3.36_1.1.25 breaks genie app, local and remote management
if you revert it back to the old firmware v1.0.3.4 will it work properly?
Message 2 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-28
05:59 AM
2017-03-28
05:59 AM
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-28
01:56 PM
2017-03-28
01:56 PM
I rolled it back to V1.0.3.32_1.1.21 bits and everything back to normal, this current relase should be pulled to fix the issues then released again.
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-30
03:24 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-30
03:57 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-30
04:11 PM
2017-03-30
04:11 PM
Did you try using the latest firmware once again?
I suggest that you factory reset the router after loading the latest fw.
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-04-01
12:54 PM
2017-04-01
12:54 PM
where did you find this firmware? id like to roll mine back
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-04-01
03:28 PM
2017-04-01
03:28 PM
http://downloadcenter.netgear.com just search R8000 and select the correct bits.
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-04-03
09:39 AM
2017-04-03
09:39 AM
Did it work after updating the firmware once again?
Message 10 of 10
Announcements
