Reply
R8000 Firmware Version 1.0.2.44_1.0.96
mondenath
Prodigy
Re: R8000 Firmware Version 1.0.2.44_1.0.96
It seems the new firmware doesnt fix the email SSL port issue. unable to use the email alert feature. Pls fix the same .
Message 101 of 118
falcon26
My R8000 worked great with my USB Flash drive plugged in. Now since updating to the new firmware it is no longer seen. Actually no computer on my network is seen by the R8000 now. What setting did the new Firmware change to make it invisable to all computers and USB flash drive attached to it? What should I be looking for in the settings?
Message 102 of 118
JamesGL
Master
Hi All,
The new firmware of R8000:
R8000 Firmware Version 1.0.3.4
Bug Fixes & Enhancements:
  • Fixes the WIN10 Edge and IE11 web browser issue.
  • Fixes the Telefonica IPTV crash issue by disabling the CTF in PPPoE mode when IPTV/VLAN is enabled.
  • Supports ReadyCloud.
  • Supports AP mode detection.
  • Supports IPv6 6rd.
  • Supports 802.11d clients for Europe.
http://kb.netgear.com/app/answers/detail/a_id/30010
JamesGL
Community Team
Message 103 of 118
mondenath
Prodigy
Hi James
This new fw does have same ssl certificate email issues.
Message 104 of 118
JamesGL
Master
Hi Mondenath,
Please check your inbox.
JamesGL
Community Team
Message 105 of 118
bwired
Initiate
please when is vpn for iphone and syslog (to ipnr) planned?
any panning for this
Message 106 of 118
carll76
Apprentice
and decent scheduling for by device access to the internet...
Message 107 of 118
alloveru
VPN Pass Through no longer works!!!!
I have a Windows VPN server that was working great until I upgraded the firmware. Now the only way I can connect to the VPN server is if I set up a DMZ (which for obvious reasons is a no go). I have tried manually readding the ports, but nothing.
Any one else having a similar issue?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 108 of 118
JamesGL
Master
Hi alloveru,
Setting DMZ is same with opening a specific ports. Have you tried resetting the router to factory default after the update? If not, then try resetting it and manually reconfigure.
Message 109 of 118
alloveru
Thanks for the reply, DMZ opens all ports, where specifying a few is a lot easier to manage the security around the select few. Yes windows has gotten better with their firewall, but I would still prefer 2 layers.
I will attempt a factory reset after the update.
Message 110 of 118
JamesGL
Master
Hi alloveru,
Is it working now? Please provide us an update.
Message 111 of 118
Mastiff
latest update: Im getting discontects on wi-fi, and intermittant connections since this latest update.
Message 112 of 118
JamesGL
Master
Hi Mastiff,
Make sure to reset the router after the update and manually reconfigure the router.
Message 113 of 118
Mastiff
really, I think I have done that several times know. I know what Im doing!
and Time Warner is stating its a problem with your R8000 router now. Also!
Message 114 of 118
JamesGL
Master
Hi Mastiff,
1. Does intermittent connection only happens in wireless or wired as well?
2. If wireless only, is it on 2.4Ghz or 5Ghz?
3. How many wireless devices experienced wireless issue?
Message 115 of 118
Mastiff
the connection intermittent is wireless, and all wirless conections have a LOS aside the outside cameras which stay connected but the one HD camera thats right next to the router is the one that keeps getting bumped off.
both 2.4ghz, and 5ghz.
the cameras and other devices; 2 DVD blue ray philips, one TV hisense, 1 iphone5, 4- X10 HD cameras. 1 iphone 6plus.
the HD indoor camera is the one thats 10 feet away from the router and keeps getting kicked off.
Message 116 of 118
JamesGL
Master
Hi Mastiff,
If you revert back to previous firmware, will you have the same issue for wireless connection? Just to verify that all of wireless devices you have mentioned are experiencing the same problem?
Message 117 of 118
JamesGL
Master
Hi Mastiff,
Please provide us with an update to your case.
Message 118 of 118
Top Contributors
Discussion stats
Announcements
