Reply
R8000 Firmware slow
DGonzo
Tutor
R8000 Firmware slow
Well I’m sure we all know that the Netgear Customer support is a joke by now. On to the point. I have downgraded my firmware to 1.0.4.28 in order to get my internet speed back. It worked as I was getting close to my 1 Gig speed I’m paying for but every couple of days or hours, I have to reset my router because it slows to a crawl. When I say crawl I mean down to below 5Mbps. I have read previously threads about going back to a very old firmware but my router only lets me downgrade so far and unfortunately that firmware is too far back. Is there any other current firmware that anyone would recommend or even a setting that I am missing? Please help!
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 6
Guru
Re: R8000 Firmware slow
After you downgraded to 1.0.4.28 (what I usually recommend), did you do a factory reset and a clean install? making sure not to use a backup configuration?
Also make sure after the reset not to enable qos, traffic monitoring, access control, or parental controls.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 6
DGonzo
Tutor
Yes I did however when I did the factory reset it would automatically go to the most current firmware.
Message 3 of 6
Guru
You should be able to disable auto-updates.
https://kb.netgear.com/000038662/How-do-I-enable-disable-auto-firmware-update
Message 4 of 6
DGonzo
Tutor
I will try this and get back to you shortly. Thank you for the rapid responses by the way!
Message 5 of 6
DGonzo
Tutor
Sorry for late response, I have been testing and as of now everything is remaining stable. I will keep monitoring and if all is good within 2 weeks time, I will mark this as the solution. Thanks for all the help and fast responses!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 250 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
