Orbi WiFi 7 RBE973
Reply
R8000 Firmware will not update
thwooldr
Router firmware will not update. current version 1.0.3.32_1.1.21 new version downloaded R8000-V1.0.3.48_1.1.33.chk. I used a hardwire connection directly connected to router. Never updates, the admin utility just sits there and  just, status bar says updating. however an hour or more passed no update to the status bar?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: R8000 Firmware will not update
Hi thwooldr,
Are you using the Desktop Genie or the web UI to update the firmware?
Message 2 of 3
All Replies
JamesGL
Master
Hi thwooldr,
Message 2 of 3
thwooldr
I was using the GUI. It never would install the fw. So I reset to factory. Then it allowed me to install the fw. Then I restored from backup. All works well now. Thanks for the help
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3460 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
