Orbi WiFi 7 RBE973
Reply
R8000 Firmware
DiVuldge
R8000 Firmware
How is the firmware 1.0.4.4? Are there any bugs or anything like the R7000 1.0.9.18 has or anything like that?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Accepted Solutions
TerryPh
Virtuoso
Re: R8000 Firmware
Hi DiVuldge
Old saying " If it ain't broke, don't fix it" applies truly in your case. Any FW version earlier and include 1.0.3.54 seems to work fine, may be at the expenses of not getting latest security update. As far as I'm concerned, R8000 is not on list for recent security risk.
I guess I have to wait for NETGEAR to come up with firmware that will work. For now, I'm skipping update firmware 1.0.4.4 and 1.0.4.2 altogether
Message 4 of 4
All Replies
TerryPh
Virtuoso
Re: R8000 Firmware
Very buggy. There are lots of discussion lately about this FW not working, most likely internet disconnection, possibly due to IP gateway messed up.
I'm staying with FW 1.0.3.54 right now after days of headaches with 1.0.4.4, and this older FW is STABLE.
I think NETGEAR is aware of the problem and is testing on the beta right now, namely 1.0.4.8
I will post update after I upgrade to 1.0.4.8.
Some people reported disconnect and reconnect again with the device hooked up with router with the beta firmware. I have to see it to myself.
Message 2 of 4
DiVuldge
Re: R8000 Firmware
So my 8000 came with 1.0.3.46, is it worth putting 1.0.3.54 on it? I've had it two days and it's stable.I'm just curious about whether I should update it and if others have problems with 1.0.3.54
Thank-You
Message 3 of 4
TerryPh
Virtuoso
Re: R8000 Firmware
Hi DiVuldge
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1621 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
