Reply
R8000 - Guest network settings not working properly?
d_rick
Continuing down the path here trying to get isloation on the guest network for the R8000.
1st - smartconnect doesn't work on the guest network. there is no option for it, and even when i name the two 5g bands the same thing with the same PSK, i still show three networks on the router.
2nd - the "Allow guests to see each other and access my local network" is checked with no way to disable. i don't want guest users to be able to see the rest of the network if i have to put them on my primary subnet (https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Can-R8000-straddle-two-subnets/td-p/1017869)... how can i turn this off?
R8000
Firmware Version
V1.0.2.46_1.0.97
TIA for any input or assistance
D
Message 1 of 2
Retired_Member
Not applicable
Re: R8000 - Guest network settings not working properly?
Any netgear router in AP Mode will allow guest to see main network. It's greyed out because it would require a V-LAN to work.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2037 views
  • 0 kudos
  • 2 in conversation
Announcements
