- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 Nas lose wan connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I bought R8000 2 months ago, i have to access my synology 713+ remotely everyday, after using R8000 every few days my nas can not be access remotely on internet i have to use netgear genie to reboot the router in order to connect the nas again. Lan access is fine. i have update to the latest firmware still the same issue. now after update netgear genie on my iphone i cant reboot my router remotely, it said "Sorry , you have an old Netgear router it does not support rebooting by genie" Can anyone help me to solve this i have do factory reset nothing works.
TIA
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R8000 Nas lose wan connection
Hi @Yodaoh,
Welcome to Community!
Does you internet connection stable from ISP and from the modem? Do you get disconnection from Internet when accesing website aside from accessing the NAS on R8000? What is the firmware version of the R8000?
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi JamesGL
Router Firmware Version V1.0.2.46_1.0.97, before upgrade to this router i am using linksys router. Everything work fine. No discconection from internet when accessing website.
This happen every 3 days, after router reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Just to confirm that your connection works fine when you were using the linksys router prior to upgrade to R8000. Also, the Internet connection works fine on R8000 without any disconnection unlike the NAS? If that is correct, have you set a static IP on the NAS?
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I just switch back to Cicsco RV042G, and make R8000 AP mode now. so far synology nas 713+ internet remote login is working. I will test for few more days before i can find the confirm.
Nas is assign static ip 192.168.1.xxx.
router assign port forward 5000,5001.
With R8000 the problem when accessing from internet port 5000 or 5001, after 24hr to 36hr it will lose all the port forwarding but internal lan accessing still work.
1. restart nas without restarting r8000, Nas still can not be access from internet.
2. restart r8000 without restart nas internet access from port 5000-5001 resume to normal.
Thanks
Jay
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have test both condition
1. r8000 dhcp assign static ip 192.168.1.111 synology nas setup static ip 192.168.111
2. r8000 dhcp assign static ip 192.168.1.111 syology nas get ip from r8000 dhcp
both condition same result after few days Nas lose both 5000,5001 port access from internet.
restart r8000 router.
right now cisco rv042g working for few days now without restart, i have to wait for few more days to confirm.
i am not sure if it is my synology or r8000 bug everything is running the latest frimware.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi @Yodaoh,
Does you NAS uses a different port numbers? If you can use a different port number aside from 5000 and 50001 then try to add it on the port forwarding and then check if you can access it. Observe the connection as well. Let see if it works with other port numbers.
JamesGL
Community Team
User | Count |
15 | |
10 | |
9 | |
5 | |
4 |
