- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 (Nighthawk X6) getting significantly slow internet via wired connection VS wired from modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I can't seem to find a clear answer to this in the forums and was wondering if you could help.
My R8000 acts as the router in my connection, and is connected to the optical network terminal/modem via a cat 5e cable.
My PC is then connected to the R8000 via a cat 6 cable.
I should be getting close to 1Gbps from my ISP, and I get values close to this when i connect wired, directly to the modem. However, when i connect wired to the R8000, i get < 100 Mbps.
I have tried changing the cables, but the issue persists.
Any advice is much appreciated.
Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Xmachina7,
1. What is the firmware version of the router?
2. Can you check the statistics of the router. (http://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router). Provide a screenshot.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Xmachina7,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 (Nighthawk X6) getting significantly slow internet via wired connection VS wired from m...
Hi Xmachina7,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 (Nighthawk X6) getting significantly slow internet via wired connection VS wired from mode
What is wired internet speed if pluged in the modem with out the router?
