Reply
Highlighted
Initiate
R8000 Nighthawk X6 won't take a USB hard drive
Hi I wonder if anybody can help me, I have a NightHawk X6 Router model R8000 Firmware Version V1.0.3.54_1.1.37 I cannot get my 6T external drive to be reconnized by the router in the USB 3.0 port. I called support and they told me I had to format it to two drives. I did as they said and it doesn't even see it there. the Drive is a WD My Book.
Message 1 of 2
Highlighted
Apprentice
Re: R8000 Nighthawk X6 won't take a USB hard drive
I have the same problem with plugging my USB HDD into the R8000 USB3 port. I have also reported the problem on 4 different occasions without any follow up from Netgear. I get around the problem this way: Unplug the power from the R8000 router, and unplug the USB3 HDD. Then plug the power back in to the R8000 (without the USB3 HDD) - wait for a complete boot up - then - plug the USB3 HDD back into the USB3 port. The HDD gets recognized, and works every time for me, and just one of three problems I have with the R8000. Hope it works for you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 842 views
  • 0 kudos
  • 2 in conversation
Announcements
