Reply
Highlighted
Initiate
R8000 Random shut down.
Recently my R8000 has been shutting itself off for a few minutes twice daily. Always between 4 and 5 o'clock. Usually near the half hour mark. Does anyone know why and know haw to prevent this. I did NOT install the latest update, so that is not the problem.
Thank you in advance for your time and consideration, and for any assstance you may be able to render.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Highlighted
Guru
Re: R8000 Random shut down.
What firmware are you on?
Did something change to start this? aka changing settings, new modem, etc
What modem are you using?
Does it fully shut down and reboot, does the wifi just shut off, wired devices, some moer details helps.
What are the leds doing when it happens?
any chance its a power issue? It does take a few minutes for it to reboot. have you tried plugging the router into a different outlet or circuit to see if theres an issue with that circuit?
CAX80-> RBK53-> GS716v2-> TP-Link M9Plus
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 152 views
  • 0 kudos
  • 2 in conversation
Announcements
